WTT Clif Designs 4800.1 LX
ray60218
I have a mint clif designs 4800.1.
Function is 10/10
Cosmetic is 7/10 its has some scratches
Mostly looking for a PS4 but will consider other offers let me know what you have
True Minimum Impedance Stability: 0.5 Ohms
Power Output Capabilities:
5200 Watts (RMS) x 1 Channel @ 1 Ohm
3575 Watts (RMS) x 1 Channel @ 2 Ohm
1500 Watts (RMS) x 1 Channel @ 4 Ohm
Unregulated*power*Supply
Full MOSFET*power*Supply and Output Stages
Sigma-Delta PlatformThrough Hole Technology
Double Sided Epoxy Military Standard PCB
Center Path Technology (Patent Pending)
Dual 0 Gauge*power*Inputs
Dual 0 Gauge*ground*Inputs
Frequency Response: 20Hz-330 Hz
S/N Ratio: >90dB
THD:
Input Sensitivity: 300Mv - 8V
Low Pass Variable Crossover: 30Hz-300Hz @ 18 dB per Octave
Variable*bass*Boost: 18dB @ 45HZ
Input Impedance: 20k Ohms
Damping Factor: >700
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
4K
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
ray60218
ray60218
Phoenix,AZ
plexlove
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
