ray60218
I have a mint clif designs 4800.1.
Function is 10/10
Cosmetic is 7/10 its has some scratches
Mostly looking for a PS4 but will consider other offers let me know what you have
True Minimum Impedance Stability: 0.5 Ohms
Power Output Capabilities:
5200 Watts (RMS) x 1 Channel @ 1 Ohm
3575 Watts (RMS) x 1 Channel @ 2 Ohm
1500 Watts (RMS) x 1 Channel @ 4 Ohm
Unregulated*power*Supply
Full MOSFET*power*Supply and Output Stages
Sigma-Delta PlatformThrough Hole Technology
Double Sided Epoxy Military Standard PCB
Center Path Technology (Patent Pending)
Dual 0 Gauge*power*Inputs
Dual 0 Gauge*ground*Inputs
Frequency Response: 20Hz-330 Hz
S/N Ratio: >90dB
THD:
Input Sensitivity: 300Mv - 8V
Low Pass Variable Crossover: 30Hz-300Hz @ 18 dB per Octave
Variable*bass*Boost: 18dB @ 45HZ
Input Impedance: 20k Ohms
Damping Factor: >700
Function is 10/10
S/N Ratio: >90dB
THD:
