1. Product:
American Bass 1000.1 AMP!!!
Both boards are original!
All 8 channel sections, as well as both sets drive cards were completely rebuilt.
All bad gate resistors were replaced, along with every fet on both boards
All buss bars were resoldered to reassure good connectivity
The entire drive section for the power supplies were replaced on each board as well.
I HAVE INVESTED ALOT OF MONEY INTO THIS AMP!
This amp was only turned on to test to make sure everything worked!
Amp repair was done by Amp Repair Center in Ohio!
2. Specs:
14.4 11,200 Watt @ 2 OHM
18 V 15,000 Watt @ 2 OHM
3. Description/Condition:
It is missing the bottom plate right now, but I am trying to locate one, which should not be a problem.
8.5/10 on Cosmetics because the amp has a couple dings and scratches on the endplates
10/10 Mechanically This amp was only turned on to test to make sure everything worked!
PRACTICALLY A NEW AMP!!!
4. What you are looking for: :
$1500 + shipping worth in trade!
WOULD LIKE CASH WITH TRADE IF POSSIBLE!
5. Pictures of your item for trade:
2. Specs:
