WTT-- 2 amps plus $150 cash for a bigger mono amp. please post pics or links to what you have. LMK...
JBL 601.1 with bass knob
Mono amp
PWM mosfet power supply(TVE)
4/8 gage Pro style terminal block for power and ground connections
Heavy duty die cast aluminum heat sink
Plexy glass viewing window
Effective Damping factor: 6.39 @ 4ohms
Frequency response:10Hz-302Hz(-3Db)
S/N ratio: 77 dBA
Maximum Input Signal:4.7V
Maximum sensitivity:220mV
hi level and low level inputs
preamp outputs
Variable Bass-boost control
12Db built in Variable Low-pass Electronic crossover
778 Watts dynamic power @ 2 ohms
580 W x 1 RMS @ 2 ohm
424 W x 1 RMS @ 4 ohms
Dimensions 15 1/8" L x 12 5/16" W x 2 3/8" H
Punch 250.2.
Bridgable to a single channel to get 250W.
Crossover frequency control with left and right gain.
62.5 x 2 watts RMS continuous power into 4 Ohms with less than 0.05% THD from 20-20KHz
125 x 2 watts RMS continuous power into 2 Ohms with less than 0.10% THD from 20-20KHz
250+ @ 4ohms bridged x 1 RMS(actually around 300)
amp on top
Mono amp
S/N ratio: 77 dBA
preamp outputs
Punch 250.2.
amp on top
