WTT-- 2 amps plus $150 cash for....
tapout
WTT-- 2 amps plus $150 cash for a bigger mono amp. please post pics or links to what you have. LMK...
JBL 601.1 with bass knob
Mono amp
PWM mosfet power supply(TVE)
4/8 gage Pro style terminal block for power and ground connections
Heavy duty die cast aluminum heat sink
Plexy glass viewing window
Effective Damping factor: 6.39 @ 4ohms
Frequency response:10Hz-302Hz(-3Db)
S/N ratio: 77 dBA
Maximum Input Signal:4.7V
Maximum sensitivity:220mV
hi level and low level inputs
preamp outputs
Variable Bass-boost control
12Db built in Variable Low-pass Electronic crossover
778 Watts dynamic power @ 2 ohms
580 W x 1 RMS @ 2 ohm
424 W x 1 RMS @ 4 ohms
Dimensions 15 1/8" L x 12 5/16" W x 2 3/8" H
Punch 250.2.
Bridgable to a single channel to get 250W.
Crossover frequency control with left and right gain.
62.5 x 2 watts RMS continuous power into 4 Ohms with less than 0.05% THD from 20-20KHz
125 x 2 watts RMS continuous power into 2 Ohms with less than 0.10% THD from 20-20KHz
250+ @ 4ohms bridged x 1 RMS(actually around 300)
amp on top
1000 rms at 4 ohms? Pm me if interested, dont need ALL the amps //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Mike, im pretty sure thats a strapped figure, it puts out 800 at 2 ohms...
no it isnt a strapped figure! look in the **** manual! it say's 500 rms at 4 ohms
800 rms at 2 ohms and 1100 rms at 4 ohms bridged. say's in the manual, so where do you get that lol. i have the manual and i even posted pics of it! it states in the manual. if strapped it would do 2200 rms. ask flakko if ya dont think the manual is right lol:rolleyes:
no it isnt a strapped figure! look in the **** manual! it say's 500 rms at 4 ohms800 rms at 2 ohms and 1100 rms at 4 ohms bridged. say's in the manual, so where do you get that lol. i have the manual and i even posted pics of it! it states in the manual. if strapped it would do 2200 rms. ask flakko if ya dont think the manual is right lol:rolleyes:
You posted the spec sheet, thats where I got the info from lol...no need to get mad, just pointing it out for you and potential buyers. If you read it it says Master slave capable in one of the rows...
Tell me how it makes sense that it puts out two different ratings at 4 ohms when it is clearly a monoblock that is internally bridged...Why would it put out more at 4 ohms? Like I said not trying to knock you, just trying to figure it out myself as it confuses me as well...
Maybe 1100 is the "acceptable" power output with minimal distortion. In that case Why not rate it at 2 ohms, or why not name it the 1100.1?
Just curious...
tapout
tapout
Ga
tapout
