Sold WTS : Orion 2500
Ill give you a clamp meter and volt meter, and an Mmats 1400.2, it needs sent in to get the rca jacks and one of the capacitors soldered back on. 90 dollars and they will fix it. Also about 17 foot of 4 gauge. And 75 dollars.
is this .5ohm stable?
Orion 2500D Specs (1 Ohm stable )
Features:
* Selectable 12/24 dB/octave variable low-pass filter
* Intelli Q bass optimization circuit and remote gain option
* Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs
* Copy/Master feature supports gain and crossover adjustment matching in multiple amp
* Switchable phase invert function
* Heavy gauge direct-wire high current satin finish power and speaker terminals
Specifications:
* Power Output:
1 x 1200W @ 4 Ohms
1 x 1700W @ 2 Ohms
1 x 2500W @ 1 Ohms
* Signal Processing:
Variable low-pass 30Hz to 250z
variable high-pass with INTELLi Q 10Hz to 150Hz
10dB of boost with INTELLi Q
remote gain capable
selectable AUX out
* Fuse Size: n/a
* Dimensions: 27.2" x 10.5" x 2.3" (691mm x 267mm x 58mm)
Coolwazabi
TITAN FAN #001
Coolwazabi
Nashville, TN
Omarvelous
