WTF??????? Trying to set gain....
JoshC
The Taco MASTA
Okay so i just went out to run the 40Hz test tone and set the gain. I turned up the volume to maximum listening volume and turned on the test tone. I have a JBL 10 in parallel at 1 ohm. I want to run 750rms to it(its hooked up at 1000 @ 1, audiopipeAPSM-1300). So 750rms x 1ohm = 750, square root is 27.38volts. But when the gains turned all the way up its only reading maybe 18volts or something way lower, where did i go wrong?
Its 12gauge db wire, its maybe a 1.5ft in length max to speaker
subsonic is set to 25-30Hz, box is tuned to 35Hz
Bass boost is off
got it, main trouble was my dmm calibration is off. Cant believe a dmm that expensive lasted only 2 yrs (over 100, ima biomedical major). Went and picked one from lowes for 40, everythings gravity //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hahaha i have no idea. Im from houston, tx so i jam SPM(obliviously its where there from), one of there songs hes raping and use's that term. I just really liked it hahahah
Most the time we loading clips,
Otherwise we holding chips,
Hittin' scores, kickin' doors,
Pimpin' ******, rollin' whips,
So we dip skunk and we slide to them Screw tapes,
Pistol in the waist line,
Money in the suit case,
Drop it in a cool place,
Everything is Gravity!
This is for streets,
Cuz my hood is my family!
Ha Ha!
http://www.youtube.com/watch?v=yW6DU11anJI check it out, its pretty bitchin, its like 8 differnt ppl. there all cold
u think? i theres a builder a my sq thread that says to used 40. He explained it all, so u think i should redo it to 50?
edit... Its actually in the thread labeled "sub wont hold long notes"
JoshC
The Taco MASTA
JoshC
Houston, tx
Danometal
