Wtf Subs Cut Out
Fender5
Bass stops for 10 seconds after playin for like 30 seconds on volume past 30. It use to be fine when I had a MAXI fuse/holder rated at 100A. I changed it for a AGU Fuse/holder rated at 80A. I also changed the speaker wires from amp to sub to 16. They use to be 12. Thats all thats diff. Wat the hell is wrong. Its still hooked up at 2 ohms. Amp is 2 ohm even 1 ohm stable. Help
How is it blown? And I think i'm going to just wire it at 4 ohms, but it cut out at 4 ohms too because the amp only puts out 500W RMS at 4 ohms
lol it doesnt take a brain surgen to realize you should put the old ish that worked back in. i doubt its the speaker wire. its probably not drawing enough current through the small 80 amp fuse
Fender5
Fender5
Arkansas
1rockford1
