wtf, Opti2000D
ultimate157
Engineering Student
I am reinstalling my mag/opti... and the reading's aren't making sense at all. I am re-setting the gains... and I'm only able to get 14 VAC out on the opti, at full gain (Yes this is in clipping territory... I have an oscilloscope)
According to the formula for wattage, P = I^2R... I am only getting 200w output. The mag is wired for 1 ohm. Measurement at the amp is a solid 14.4vdc.
My HU pre-outs are only capable of 2v. Sub is set to +1, volume to 45/62.
Does my HU **** that bad?
Opti is rated for 1600w @ 1 ohm.
you have it on Master, right?
also set your gain on vol 61/62, yes I have an oscope, yes I checked, that's where most pioneer's clip.
I'll go see what it'll do @ 61.
Hrmph... I forgot I was using a -6db tone. I meant to switch folders on the mp3 cd.
0db @ 28hz, 61/62, sub set to 0, gain at max (oops) it read 68v. Needless to say I turned it off real quick.
Theoretically, thats 4600w if it were to have a 1 ohm load on it. Oops.
Ah the power of oscilloscopes. Got everything tuned in, and **** does the mag blend perfectly.
Ended up with the volume to 50/62 for normal playing, 55/62 if I want it louder.
EQ settings (Very limited with this deck)
Low +6
Mid +1
High +1
Checked the RCA's, zero clipping. Ended up with the gains on both my amps lower than I had them setup previously. Opti's gain is a LOT lower now, probably ~20% outta 100%
The CDT's sound a lot better now also. Now that the RCA output voltage is higher, and the gain on the amp lower. Couldn't be happier. (Until I go active, of course //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif)
Set the gains on the mag for 34v, or 1150w.
You were right.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif And a very odd circumstance I must say. 61/62, the sin wave was perfect. One more click to 62 and it clipped pretty bad.
ultimate157
Engineering Student
ultimate157
Worcester, ma
DBfan187
michigan born
    May 14, 2026
michigan born
    May 14, 2026
