Wtf Is Wrong!!
what gauge wire are u running. Make sure ur Subs ohm load is wired correctly. Make sure everything is connected properly and make sure ur inline fuse isnt blown or any other fuses on the amp.
Genearlly an amp will not go into protection with a to high gauge of wire. 10 Gauge is enough to turn it on and keep it on.
MY main feeling is that your subs are not wired correctly.
I would wire it up to 4 ohms. Test, then down to 2 and test.
Genearlly an amp will not go into protection with a to high gauge of wire. 10 Gauge is enough to turn it on and keep it on.MY main feeling is that your subs are not wired correctly.
i agree. power wire wouldn't make an amp go into protection mode i believe. it might make the amp produce less power than expected but not in protection mode.
check how you wired ur subs again, and check your ground, make sure it's a nice clean connection.
man u guys dont understand i fuxed up my amp cua the power wire was to small..
so it might not go into protection, but could still mess it up..
cuz mine neva did..
Kicker4Life
Kicker4Life
Diboll, TX
djjdnap
vegang
vegang
