WTF Check Engine light's on...
SethPhillips
I'sa Playa
gotta 99 acura integra .. it's the model next to the gsr..
check engine light came on mid day yesterday... anyone know what it can be.. everything looks fine. sounds fine.. just changed my oil/ oil filter monday...//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused:
I have an RSX and my service engine light just came on and I had to manually reset it... I wonder if this is the same thing.
Did you gas up recently and not get the cap on right??? I've had that happen a few times with my RSX and also my g/f's Sentra SE
is your gas cap on tight?
could be anything really, take it to a shop or somebody who has one of those things that tell you what it's on for.
You probably need to check your engine. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
x2.
more than likly its a sensor of some kind.
mine has been on for 200+ miles. its the knock sensor but im too broke right now to go out and get it.
well no **** dude..
just checked over my vacum lines, gas cap's tight, oil look's good and is at the right level... radiator fluid level look's good... i think it might be my O2 sensor's.... i'll go have atozone pull the codes when i get off of work..
well no **** dude..just checked over my vacum lines, gas cap's tight, oil look's good and is at the right level... radiator fluid level look's good... i think it might be my O2 sensor's.... i'll go have atozone pull the codes when i get off of work..
i did that the other day. they just need your drivers lisence , so if you take off with thier scanner , they know where to find you.
mine comes on randomly and its always the EGR valve. i don't what kinda gizmos your integra has but if everything seems fine i bet its something emissions related...
ahhh i forgot.. i know a guy that is a tech at the honda service center at the local honda dealer!!!
he recomended a bunch of ****... he said he would go over the whole car.. and do my timing belt and check my valve clearence for $500.. so i think i'll do that once i get PAID!@
lol, 02 sensors **** to replace, mine went out on my old maxima and it was 600 to get fixed by the dealership. Prolly cheaper somewhere else, but still probably a few hundred.
other then ebich coilover's and a cold air intake it's bone stock....
mine are easy to replace.. i just dont want to replace them till i get my skunk 2 full exhaust system.. not to mention i need 2 O2 sensor's at $95+ a pop!!!
like i said , just go to autozone first and see what the problem is. it may be a simple fix , it may not be. so unless your car is due for belts and everything else you said , it may not be worth it.
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
BASSMEKANIK
SlugButter
    May 4, 2024
slater
    May 2, 2024
