WTF Check Engine light's on...
SethPhillips
I'sa Playa
gotta 99 acura integra .. it's the model next to the gsr..
check engine light came on mid day yesterday... anyone know what it can be.. everything looks fine. sounds fine.. just changed my oil/ oil filter monday...//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused:
I have an RSX and my service engine light just came on and I had to manually reset it... I wonder if this is the same thing.
Did you gas up recently and not get the cap on right??? I've had that happen a few times with my RSX and also my g/f's Sentra SE
You probably need to check your engine. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
x2.
more than likly its a sensor of some kind.
mine has been on for 200+ miles. its the knock sensor but im too broke right now to go out and get it.
well no shit dude..
just checked over my vacum lines, gas cap's tight, oil look's good and is at the right level... radiator fluid level look's good... i think it might be my O2 sensor's.... i'll go have atozone pull the codes when i get off of work..
well no shit dude..just checked over my vacum lines, gas cap's tight, oil look's good and is at the right level... radiator fluid level look's good... i think it might be my O2 sensor's.... i'll go have atozone pull the codes when i get off of work..
i did that the other day. they just need your drivers lisence , so if you take off with thier scanner , they know where to find you.
ahhh i forgot.. i know a guy that is a tech at the honda service center at the local honda dealer!!!
he recomended a bunch of shit... he said he would go over the whole car.. and do my timing belt and check my valve clearence for $500.. so i think i'll do that once i get PAID!@
lol, 02 sensors **** to replace, mine went out on my old maxima and it was 600 to get fixed by the dealership. Prolly cheaper somewhere else, but still probably a few hundred.
mine are easy to replace.. i just dont want to replace them till i get my skunk 2 full exhaust system.. not to mention i need 2 O2 sensor's at $95+ a pop!!!
like i said , just go to autozone first and see what the problem is. it may be a simple fix , it may not be. so unless your car is due for belts and everything else you said , it may not be worth it.
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
BASSMEKANIK
BP1Fanatic
BP1Fanatic
