WOT
Banned
Im having a SERIOUS noise problem in my system.
What Ive got:
pionner premier 860mp
kicker kx 650.4
cadence txa 1000D
The system was playing fine for months, then I switched back to this stereo setup with only 2 12's and the rxa to power them, played fine the first day of the install then went crazy after playing perfectly fine the next minute. The speakers made that noise and the subs were kind of making a rumbling noise
You can play it at lower volume and it will USUALLY play perfectly and quietly. Crank it and this high pitch little record scratch noise starts coming through!
People said it was my pionner deck, i found out a common problem with the pioners and fixed it myself, reinstalled, and the noise was still there. Then I swapped in a kenwood kdg230 lower end deck but perfectly working. Same noise.
So obviously its something thats still installed in my car.
When I had the pionner installed, I disconnected all the amps from the back of the deck via rcas and ran ONE speaker back to the deck and ran that speaker off the deck wattage, played perfect upto full volume.
I personally think it may be the kicker amp, but I dont have anything to substitute in its place at the moment
Anyone got any tips on what it could be causing this horrible noise?
I should probably mention. The power wire and rcas are run on opposite sides of the car. Both amps have there own set of rcas, and the kicker is a 4 chanel so I split its rcas at the amp to give myself 4 connections
$20 to whoever solves it, I could care less about the money, I want this solved.
What Ive got:
kicker kx 650.4
cadence txa 1000D
