Would you guys buy power supplies?
or you can just get one of these and it would be better because you can adjust the voltage and its made to charge a batt bank and run 12V electronics not a computer at 12V flat
i like your idea but bang for buck this is way better
those are legit, im just saying if i can get a 30amp load out of a psu that someone mails me or grab one on sale and mod it, it may be a good route for people here.
15a and rated for 180 watts isnt going to get you very far, unless your running the hu by its self, but if you want to run a couple amps for a home setup/test bench your going to need something with a bigger pair than that has.
15v and rated for 180 watts isnt going to get you very far, unless your running the hu by its self, but if you want to run a couple amps for a home setup/test bench your going to need something with a bigger pair than that has.
i was just thinking a HU and 4 speakers of HU power or a small 4 channel.
Done
Power supplies starts to get expensive when you want one that does over 30A @ 12~15v DC, I remember the ~800A power supply that caraudiomag used to test the JBL 6000GTi and it wasn't exactly enough.
If you want to test/run big amps it will be cheaper to just get a big battery charger and a couple of gel cell batteries and call that a power supply.
lol im not running a bajillion watts its for small projects and i will make them and sell them for cheap as balls or you can mail them to me and ill do it for cheap as hell
Me too and then I have to paddle anywhere I want to go.
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
nateberrier
nateberrier
Douche, Ohio
surreal
    Jun 15, 2024
    Jun 15, 2024
