would i JBL 1200.1 be able to power 3 Type R 12's
  • 2
muffmanaj
iowa
I was wondering if my JBL 1200.1 would be able to power 3 Dvc Type R 12's Right now i am running 2 off that amp and can barly turn the gains up without it distoring but it is loud also how would i wire them to the amp
Also anyone know where to get a good box for 3 12's
first of all the gain is not a volume control. it is a method of matchin the amps input with the decks output to do it near perfect use a volt meter and an ociliscope lol or read the instructions to your amp (it should tell u a ballpark way to set it without the before mentioned equipment) and do you know how to figure impedence? do you know what it is to wire in series and or paralle?
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
muffmanaj
muffmanaj
iowa
audiolife
    May 16, 2024
    May 16, 2024
