Currently I have 2 12" Dayton Audio HO (well, 1 now) in a sealed enclosure. 1.1cf each. I blew 1 sub a few weeks ago, no clue how I did since I don't normally play them loud. I heard a weird "tinging/rattling" noise from the sub then it just quit after. When you press down on the top it would make a scratching noise then wouldn't move at all. Well, the other sub I have is starting to make the same tinging/scratching noise at low volumes but not at high volumes??? Doesn't make sense. So, I'm assuming that one is going to go out soon as well. I only had them for almost a year. The amp is a JBL GTO1201.1 amp. Both subs are wired @ 2ohms for 1111rms.
Instead of re-buying the Daytons I want to try something that won't blow out on me in a short period of time. I love the SQ of the Daytons, would Image Dynamics be just as good or better than the Daytons in the SQ department?
If so, which ID subs would be a good choice in a small sealed enclosure with 787-1111rms of power?
