jacko 10+ year member
Okay. Yes i used the search function but did not find quite what i was looking for. i think I have the worst noise/whine problems ever in my '97 Bonneville. The noise/whine(i'm not sure what) is louder than the music when the car is on. symtoms: The car is switched to acc, and I turn on the deck(pioneer DEH2600), The power antenna going up makes a ton of noise come from the speakers. After this, there is noise coming from the speakers(not as much as when the antenna was powering up) (all speakers are amped in the trunk, along with the subs), and increases with volume. When i start the car up, The noise is just unbelievably loud from the speakers. However I cannot detect any noise coming from the subs. My grounds are down to metal for both amps, I'll try moving them towmrmow, but i don't think it's them because i tryed taking off the RCA's with the deck on, and after this there was no noise that I could detect, i could be wrong though. Couple questions about controversial things: How long can a ground wire be(short as possible i know) i've heard anywhere from 1.5 feet to 3 feet. Do speaker wires next to the power wire create noise? Does the RCA wire nxt to the pwr wire create noise? How far away? i should also mention that i've already had an amp in the trunk for a single sub, and rand ran the speakers from the same deck prior to this, without noise.
