Title says it all. Prior to the 3, only the dash would slightly dim. Now, everything including the parking lights are dimming a lot. The wires are 1/0 and in the correct positions with factory electrical. The battery is at 10.47V with the car off, haven't had the chance to check it with the car on, but will do that ASAP.
Anyone have any suggestions? I have a couple ideas of what could be the source of the problem, but I'm not too sure about them. First off, the battery - and engine are grounded from the factory in the same location; where I also grounded the 1/0. Second, the factory ground from the engine to chassis isn't directly from the block itself but from an attachment to the block. Will I need to find a different location for these and maybe ground them separately?
The setup is a single Type-R 12' DVC at 2 ohms pushing 800 wrms on both the factory battery and 100A alternator, if that helps. Thanks for any input.
