worklog, boxbuild, pics... four cw12's
.5ohm Split it so .25 each, those amps will like .25 daily, even with box rise.
You can strap them to 2ohms, and still have extra headroom.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks, your more than helpful. so they will run at .25 ohms, and also, last question i promise, how much current do you think they would want?
*won't like .25ohms daily*
I wouldn't let me edit.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I'd opt for 2ohms.
so each amp would put out its 1 ohm rating? that would be lovely! and since u run one and have experience, how current hungry are they?
yes, they would do there 1 ohm power rating, or whatever they do at 1 ohm...
so if they are rating the amplifier power using a 1khz signal how is that going to affect the power rating when playing below 80Hz? so what im realy asking, is the power of the amp going to decrease when played at lower freqs?
they are stating that the amp would put its max or rms output power at 1khz. how could that be use as refrence for subfreqs?
sorry if im out of text here, just wondering.
so if they are rating the amplifier power using a 1khz signal how is that going to affect the power rating when playing below 80Hz? so what im realy asking, is the power of the amp going to decrease when played at lower freqs?they are stating that the amp would put its max or rms output power at 1khz. how could that be use as refrence for subfreqs?
good question
just an update... my xx-goliath should be in this week, and vid's soon to follow //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
jeepintn
jeepintn
Greenbrier, TN
jeepintn
