working with aluminum
d4vew557
15
uk
I am planning on putting aluminium surrounds around the sub the perspex window that will display the amps. the problem is i'll have to make them and it's something i have never worked with before.
Looking around a few sites it seems the way to go is cutting the shapes out with a router, does this need special bits or just normal router bits
How do people achieve such a mirror finish
Any tips working with alu would be a big help
Its just fiberglass resin mixed with dye, google search fiberglass resin dye.
You just mix the dye and hardner into the resin, apply the resin, wait for it to partially dry, then apply another layer. The more layers of resin, the blacker/deeper the color will be. Find yourself a clear resign for the best results.
Don't forget to use the 'thanks' button at the bottom left of posts if they helped you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I recently cut holes in my aluminum computer case. using a router. Make sure you wear gloves, eye protection, something with long sleeves, and a face mask. It's not as dirty as cutting MDF, and is easier to clean, but it's basically just shrapnel shooting all over the place. Be sure to clean your work place well or you'll puncture a car tire.
d4vew557
d4vew557
uk
lil azn 06
