Woffers.. Need help
BassBoi
13
NY
Hey i have a Sony X-plod Class D 1000 watt amp...
and I have no idea what kind of woffers to get...
If any one can give me a few suggestions it would be really helpful
The amp can take up to a 4 om Load.. i think ( correct me if im wrong)
these are the Specs
Frequency Response -- 5-300Hz (+0/-3dB)
Harmonic Distortion -- 0.06% or less at 1kHz, 4 ohms
Speaker Impedance -- 1 - 8 ohms
Input level adjustment range -- 0.2 - 6.0 Volts (line level), 0.4 - 12.0 Volts (speaker level)
Power Supply Voltage -- 10.5 - 16 Volts
Current Drain -- At rated output: 40 Amps at 4 ohms, remote input 2.0 mA
I need some real thump... If possible feel the bass if im standing out side the car...
I have 200$$ to spend on the woffers... so if you have any suggestions please let me know
ThnX
$200 is really pushing the bottom end of things...the 12W0's are probably the best bet...just like what kid said above. If you get them, get single voice coil 4 ohm speakers...wire in parellel and you amp will run at 2 ohms...plenty of power...and it will handle this okay.
Why type of vehicle...box design really helps make the bass good...but who cares how it sounds OUTSIDE ?!?!?!
...I just don't get that...
I got 2 really good JBLs
for about 70 buks each....
poly woofer with butyl rubber surround
dual voice coils
dual magnet structure
power range 18-300 watts RMS (150 watts per coil)
peak power 1,200 watts
frequency range 18-500 Hz
sensitivity 93 dB SPL
top mount depth 5-15/16"
sealed box volume 1.25 cubic feet
ported box volume 2.0 cubic feet
That Class D Sony supposedly makes 1000 watts RMS@1ohm. I almost got it instead of my bd500.1. In that case, you should run two dual 4 ohm subs with everything in parallel, and they'll receive 500 watts RMS. The thing is, I don't know if the Sony amp REALLY makes 1000watts. Has anyone tried them out?
I heard that sony amp hooked up to 2 mtx 6000 12's. It hit pretty hard the volume wasn't turned up very high and I can't remember exactly how the set up was. Just make sure your amp can push the rms of whatever speaker you get
BassBoi
BassBoi
NY
