I don't wanna use a 1ohm amp....That is my point...amp is 2ohm....Im not sure if this is possible.....If not I will just run 2....But I would like to run all three...
can't find the specs on that but judging by the other pa amps, it is not 2 ohm stable bridged. 2 svc 4 ohms subs would be 2 ohms and that wouldn't work so basically all you can do is wire one sub to one channel for a 4 ohm load on each channel
