Wiring up DVC
I'll just tell you have I have and you can tell me which would be the best my to wire it up of if the set up is even compatable.
2 10" Pioneer TS-W254DVC
Dual Voice Coil (2x4ohm)
500 Watts Max Music Power
250 Watts Nominal Power Handling
1 Pioneer GM-X962 760 Watt 2 Channel amp
Continuous Power (14.4V): 125Wx2 (4 ohm), 190Wx2 (2 ohm), 380Wx1 (4 ohm)
Max Power (14.4V): 250Wx2 (4 ohm), 760Wx1 (4 ohm)
Or would i be better off with the single voice coil sub:
2 10" Pioneer TS-W254C
Single 4 Ohm VC
thanks
PuN
go to the rockford site and look for the wiring wizard that will answer all your questions
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Parralel each sub so its impedence is 2ohms and run the amp in stereo mode, this is how you will get the most out of your amps/subs, unless you want to series parralel them and end up with a 4ohm load and then you would bridge you amp.
_PuNiShEr_
68 Camaro
_PuNiShEr_
Iowa
_PuNiShEr_
