Wiring to 1 ohm with 2 single boxes
wire the subs to 2 ohms per box. then both subs to the amp on one channel. 2 + and 2- together. BAM 1 ohm
but when you say " then both subs to the amp" do u mean twist the positives together and the negatives togther and then plug those wires into the terminals...like it's + - + - , so theres stil a + and - with no wire in it?
if you have 2 + and - speaker inputs on the amp, they are paralleled internally, so wire both subs' voice coils parallel to make them 2 ohm a piece, then wire one sub to one + and one - and wire the other sub to the other + and -, tada, 1 ohm load
Newff
Newff
Fort McMurray, Alberta
jco1385
NorthFramingham
    Jun 30, 2026
