Where to ground amplifier in 2002 altima
dakayus
LA
Hey guys I'm trying to figure out where to ground my amp. I really can't see any screws in my trunk. I took out the carpet and stuff and I just see rivets and weld points. Is there some spot that I'm missing? There's 1 screw i see but I can/t get to it. It's holding the backseats in place at a weird angle and it's too big for my ring thing. I'm using 8 gauge knuckles kit.
Thanks!
Pick a spot, grind down the paint, and use a self tapping sheet metal screw (Not a tiny one)
Make sure nothings on the other side of the sheet metal.
That's just asking for trouble as the screw will get loose. You need to drill a hole and use a lock washer/lock nut with a bolt.
dakayus
dakayus
LA
ultimate157
