Wiring Tail Lights
  • Thread starter MikeRupp
  • Replies 0
  • Views 545
MikeRupp
NJ
Hello Gentleman/ Ladies,
I make custom tail lights for the Toyota Supra MKIV's (93-98's). My current project has me wiring in sequential turn signals. Like the old cars where you have three different bulbs for the indicators. When you hit the turn signal the lights blink slowly from inside to out.
Here is my problem. As it sits, I have the module to make them flash how I want it, but when I do use the indicator the running lights (dim brake lights) and if pressed, the brake lights will stay lit while the indicators are activated.
What I need is for the brakes and the running lights to be completely disabled until the indicator has returned to its normal position. As in, I do not want to see the running lights in between the blinks.
I was told that I need to have the brake & the running lights on relays and then need to have a capacitor before them to make the circuit stay on while the indicator is active.
The tail lights have 4 circles. We are focusing on the last 3. The two in the middle are brakes and running lights. Both brakes are tied together for ease of wiring as well as the running lights are tied to each other.
The indicator control module has is connected to all three and has a power input.
So if the lights were in front of you, you would see 4 different wires. Grounds, Brakes, Running and Indicator.
I really need help with the wiring diagram portion of how to I get these to blink like the older cars or the brand new Mustangs.
Thank you in advance,
Mike
PS. I am not sure if I can post up links to my website or not, but if anyone would like to see pictures please PM me and I will send some pictures.
And I will try to attach a picture of what I am talking about later, IF I CAN.
MikeRupp
MikeRupp
NJ
MikeRupp
