HOw much power can my elec. system handle?
Wow that alternator sucks. I really can't help you unless you tell me what's your goal. But I can tell you whatever you plan on getting, or even with your curren setup I would upgrade your front battery. Maybe an optima or something.
That is the upgraded battery. My current battery has about half the cranking amps of the duralast. And obviously, my goal is bigger louder bass.
Oh, and an optima isn't compatible with my car.
bigger and louder bass won't do. That's not a goal, you sound like a spoiled kid with a trunk full of Xplodes. What do you wanna run? That makes no sense
Actually I'm the total opposite of spoiled, I don't really own shit and never have for that matter. I want a louder system with more bass. Understand?//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
I was thinking of upgrading to the ZX750.1 but don't know if I could handle that with my current alt.
And you couldn't say this in the first place because...........................................................................................................................................................................................................................?
You could probably pull a solid 1.5-2k without serious issues. That is certainly fine.
I guess because I'm not as smart as you kind sir. Don't you see my post count? I'm new at this. Could use more help/input instead of dyckhead comments.
1.5-2k is much bigger than I want but thanks for the input, that is all I was asking for was a little help. JEEZE
It has nothing to do with knowing about car audio, it has to do with common sense. It's much easier to answer a specific question than a hypothetical and ambiguous one...
You gotta more precise with your questions, it's like shooting in the dark. But like the post above 2k at the most with some strong batteries. I believe the usual car uses about 30 amps, and since yours is around 80, that's about 50 amps for audio. So youbetter have some d*mn good batteries.
Well if you don't have any experience with an alt around the size of 83 amps then I guess you can't help much.
You gotta more precise with your questions, it's lime shooting in the dark. But like the post above 2k at the most with some strong battery. I believe the usual car uses about 30 amps, and since yours is around 80, that's about 50 amps for audio. So youbetter have some d*mn good batteries.
thank you.
wow...that started off well. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
why isnt your car "compatible" with an optima? i assume its a 12v nominal system right?
anyway, you should be fine with that battery and some restraint with the gain. dont blast your ish at idle for an hour, lol. also...the big3 should give you huge improvements.
yt's not for my ride either cant get one
Yeah I searched for the make/model of my car and there wasn't anything compatible. I'm sure that maybe there could be a way to rig one but I'm gonna buy something I am sure will fit.
Yeah I played it too much with the car off and the battery sucks to begin with and its also winter time so my battery is crap at the moment. The Big 3 is something I will probably do as well. Thing is, my alt is very well hidden so I hope I can do it on my own.
Solo-baric
Newbie
Solo-baric
Minnesota
Solo-baric
