wiring speakers in series
  • 2
rboliver
I understand how to wire speakers in series, my confusion is that each speaker has its own crossover. Do I just wire the crossovers in series? In other words wire the positive input on one crossover to positive speaker wire from amp and negative speaker from amp to negative input of second crossover. Then connect the other inputs together. The speakers would then get connected to the outputs of the correct crossover. Need to wire in series due to impedance. Thanks in advance for your help
dont overthink it. past the crossover, to each speaker, it doesnt matter. you want to be concerned with where the power is going into the crossover/component set. that's it.
wire the positive of the amp to the positive of the first component set input, and the negative of that first set into the positive of the second set, and then the negative of the second set back to the amplifier.
this is if you're talking about midrange speakers. subwoofers should not have passive crossovers
Thank you for your help. This is for midrange/tweeters. I think I got it. So the speakers would just connect to the positive/negative of their respective crossover?
correct, wherever they're designated to be connected. follow the manual and markings for that aspect of it
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
6
919
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
rboliver
rboliver
los angeles, ca
wew lad
Latest topics
