Wiring sizes for setup
zit501
Hi all,
The setup is as follows:
Kicker KX800.4 AMP
Infinity Kappa 60.5cs comps
Infinity Kappa Perfect 12.1 svc sub
Questions:
-What size (Gauge) wire should I use from the amp to sub, and amp to comps?
-Is 4 Gauge big enough for that amp?
-What is a good well-priced kit that should have most of what I need?
Many Thanks
Mark V
4 ga kit is fine---go to wal-mart to buy the kit---just make sure the kit has shielded rca's and that'll be just fine. As far as wire to comps--if your crossovers have built in wires just get a comparable size if they don't have built-in's just buy a roll of 12 or 14 gauge wire while your at wally world.
Ya, wal-mart is a bit far... I live in South Africa... Anywayz, what size do you think for the sub?
Oh, don't worry. Here in SA with welding your are seen as skilled labour. It is a real skill! So's bricklaying... but I know that Americans don't do alot of bricklaying.
Ya, wal-mart is a bit far... I live in South Africa... Anywayz, what size do you think for the sub? Oh, don't worry. Here in SA with welding your are seen as skilled labour. It is a real skill! So's bricklaying... but I know that Americans don't do alot of bricklaying.
thanx for the bit about welding--anyways i would say some 10 or 12 gauge speaker wire for those subs would be just fine.
zit501
zit501
Cape Town, South Africa
bonesninja
