Wiring second battery?
Jacobman
CA
So do you just run wire from positive to positive and negative to negative form the engine to trunk? Then can i power and ground my amps on the battery in the trunk or power them but keep the ground they are currently using?
What about the the grounding of the amps? Also would 4guage be sufficient enough for the wiring of the batterys?
ok, i got a stinger 600 batt and i want it in the trunk, do i just connect the power wire from the positive batt post under the hood to the positive post in the trunk and then that wire to the + amp imput. and then for the batt in the trunk, ground the (-) post?
Did you read the thread at all?
nG
Are normal battery posts 5/16" like some OEM one from kragen, or should i buy 2 new ones from knukonceptz?
Jacobman
Jacobman
CA
Jacobman
