Wiring Question
So I am running a 4 channel amp,
I am looking to run my MTX Terminator Sub As well as my speakers.
I've never done anything before with amps, although I know how to do speakers.
I am assuming that the Sub gets its own channel, Which speaker should get which channel?
(I have two front doors, and two rears)
Secondly,
How do I know whether or not that spot that I chose to ground my ground to is a good enough ground?
What resistance coils does your sub have? If it's got dual 2 ohm coils or is single 4 ohm, you can bridge two channels for the sub and run your speakers off the other two channels.
Google how to bridge an amp and do some research. Lots of people do this with low power audio installs. There's lots of information sitting around the web waiting for you
How can I tell?
This is the sub:
MTX Audio Terminator Series TNE212D 1,200-Watt Dual 12-Inch Sub Enclosure
Dual 12" Subwoofers
Single 2Ω Enclosure
1200W Max Power, 800W Peak Power, 400W RMS
How can I tell?
This is the sub:
Dual 12" Subwoofers
Single 2Ω Enclosure
Single 2 ohm, no I wouldn't recommend bridging the amp for that.
You can get a cheap little Boss or Planet 2 ohm stable monoblock amp though. $54:
Boss AR1500M 1500W Monoblock Armor Series Class D Car Amplifier
dacfleming
dacfleming
Pleasant Valley, NY
adulbrich
