wiring question
[quote name='>>SQL
Shut UP Noob!
5 1/2" speakers need a 4.4" cutout which may or may not fit in a 4x10 speaker cutout' date=' that is why I also recommended 4" mids.
Plywood cause it is easy to work with and if you have ever been in a older muscle car you would know that they have a thick foam dash pad over the speaker area so using plywood is just fine.
Jezz were you bullied too much in High School or something?
You are a acting like a thin skinned child, take a look at that. I am sure you can be a better person if you just try a little.[/quote']
LOL he said plywood. a 4.4" cutout.. i think thats still bigger than 4" ya again my math is a bit rusty.
[quote name='>>SQL
Second while summing hte front channels (neg from on side pos from other) may work but I do not think it is worth the risk to your headunit.
What you should do is pull the 4x10 out of there, use the speaker on 1/4 plywood to make a template. Cut out the 1/4 plywood to fit 2 - 4" or 2 - 5.25" drivers in the same spot the 4x10 went.
Now you can run stereo front and rear and I think it will sound better.[/quote']
HU speaker outputs are identical between channels. There's no risk hooking a speaker between them. I think that's how center channel OEM setups are done. I agree that two 5.25's would be a way better idea though. And if the OP is ok with taking a jig saw to the rear deck it wouldn't take much to fit them.
71dodge
71dodge
somewhere
maylar
vegang
vegang
