wiring question
71dodge
hey guys i have a muscle car with one 4x10 4ohm speaker up front and two 6x9 4ohm speakers in the back. and i have a 4 channel head unit with 50 watts per channel. Can i wire the left rear speaker to the left rear channel the right rear speaker to the right rear channel and the single front speaker to the right front channel and leave the left front channel un-used.
will this work?
thanks.
maybe, but that wouldn't be better than running it 3-channel. you know they make different 4x10 options to solve your problem. or could do 2-3.5, or 4" mids in it's spot. some of the shelf options include dvc 4x10, 2 smaller speakers already formed into a 4x10 plate, a summing transformer that will turn both front channels into one, etc...
ok so i can wire the front speaker positive to the LF ch. and the negative to the RF ch.
and if my channels produce 50w each will it still be 50w if i wire up the front speaker that way. and also will it still only produce either right or left sound?
how will it affect my balance and fade.
thanks guys. im not new to wiring just never have wired a 3 speaker setup.
ok so i can wire the front speaker positive to the LF ch. and the negative to the RF ch.and if my channels produce 50w each will it still be 50w if i wire up the front speaker that way. and also will it still only produce either right or left sound?
First thing is no head unit produces 50 watts per channel, that is a MAX rating and means nothing.
Second while summing hte front channels (neg from on side pos from other) may work but I do not think it is worth the risk to your headunit.
What you should do is pull the 4x10 out of there, use the speaker on 1/4 plywood to make a template. Cut out the 1/4 plywood to fit 2 - 4" or 2 - 5.25" drivers in the same spot the 4x10 went.
Now you can run stereo front and rear and I think it will sound better.
[quote name='>>SQL
Now you can run stereo front and rear and I think it will sound better.[/quote']
Maybe you should hang out for a while before you start posting.. Did you say plywood?
OP, thats a $3 adapter.. allows for 2 3.5" speaks.
Course you could just go with plywood.. then seal it so the sun doesnt warp it.. then somehow make it look good.. but 1/4" plywood with very little surface area will most likely crack before warp.
and my math might be rusty but if you have a 4" speaker how would one fit a 5.25" speaker in the same area? much less 2.. isnt that 5 x 10.5" in a 4x10 spot..
just me i guess.
course im just a noob here.
but id do it right and grab the adapter.
just me i guess.
//content.invisioncic.com/y282845/emoticons/popcorn.gif.32dd9e22fd77e77bc3c907062768fcd2.gif
thanks guys.
ok i think i got an idea. could i just wire the two rear speakers up as normal and just go with them. will the extra 4x10 even make a difference?
Also Would it be possible to wire the 3 speakers in parallel as a mono setup?
Thanks Again
Seriously you must be the biggest butt hurt person in the entire internet.
Shut UP Noob!
5 1/2" speakers need a 4.4" cutout which may or may not fit in a 4x10 speaker cutout, that is why I also recommended 4" mids.
Plywood cause it is easy to work with and if you have ever been in a older muscle car you would know that they have a thick foam dash pad over the speaker area so using plywood is just fine.
Jezz were you bullied too much in High School or something?
You are a acting like a thin skinned child, take a look at that. I am sure you can be a better person if you just try a little.
just me i guess.
71dodge
71dodge
somewhere
maylar
vegang
vegang
