wiring question
What kind of subs are they? SVC? DVC? 2-ohms, 4-ohms, 8-ohms? And I've never heard of Audiokraftwerk but what load impedance will it support?
vanadium
2 x 3.6 Ohm
nominal = 50 - 350 Watt
peak = 600 watt
Audiokraftwerk
rms @ 2 ohm = 730 watt
rms @ 1 ohm = 1000 watt
both are by rainbow
Yes. Set the gain with a 40Hz 0db test tone and DMM. It will only hit 500 watts on the loudest of bass hits, and only for a split second. Most music will be sending around 300-400w. Your subs are rated for 600w peak, so you'll be fine.
Of course, the absolute safest way to set the gains, will be with the same test tone, but set the gains for 350w max. Then you're sure to never have a problem.
scarysoul
scarysoul
Brunei
kross
