wiring question for 1000.1bd amp
How are you wanting to wire the sub? 8 ohm or 2 ohm? For 2 ohm loads, put both the postive leads together in the positive speaker output, and the negative lead in the negative output on the amp, for an 8 ohm load, put one of the positive leads in to the OPPOSITE coil's negative lead, then take the remaining 2 leads and put the positive lead in the positive output, and the negative lead into the negative output.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4
kingkung
kingkung
Huntington Beach, Ca
kingkung
