Wiring problem...i think
  • 2
Lewbrah485
hello, i've been installing my system w/ a friend of mine and we got everything hooked up and when we went to turn on the subs, nothing happened. we checked the wires and we are 99.9999 % sure that its right. The only thing is that a fuse keeps blowing for the panel lights where the speeddomintor etc. is. I replaced it and it blew again. At first we thought that my amp was just a bad amp and i needed to be sent a new one but now we are thinking its a wiring problem. Any help will be greatly appreciated!! THanx
i had the same prob with the fuses for speedo blowing fuses what u gotta do is rip out your head unit and electrical tape all your cabling to amke sure nothin is touching
the amp could be that u havent hooked it up to a remote wire what actually turns it on otherwise your ground connection isnt good, otherwise have u connected power cable to right battery terminal it has to be connected to positive
hope this has helped:)
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
219
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
623
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
662
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
654
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
562
Lewbrah485
Lewbrah485
Pittsburgh, PA
JONNY_MTX
