Wiring Plan
I know you guys are probably sick of my questions... but I'm trying to figure out how I'm going to wire up my setup for Street Max 1-2. I have to have the battery under the hood, so no matter what it's going to be an expensive task.
A guy I know builds distro blocks/battery terminals and he recommended:
For the battery, I suggest the terminals accept (4) 4/0 power wire and (2) 4ga wire. You will need 2 of these (one for power and one for ground). You will have a total of (8) 4/0 wires going to the rear of your vehicle.
In the rear......(2) distro blocks. Each block would accept (4) 4/0 wire. On the output side you would have (4) 1/0 and (2) 4ga outputs. The ground block would have an additional 4/0 output to ground to chassis.
But that seems a little overkill. I'm thinking I'll be alright with two positive and two ground from battery to Warlord (it accepts 2 power/ground). What will the extra wire really gain me, a tenth of a dB?
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
Kenny Pollock
