Wiring OEM Deck w/ NAVI Acura TL
fresh2o
Anyone wire a OEM deck w/ NAVI on a Acura TL?
Problems I'm having is that the OEM deck controls frequency sent out through speaker wires. The issue is that as I turn up the volume, the deck is turning down the bass, so that if I had stock setup, it wouldn't distort. Anyone know of a way to counter this with a different wiring setup?
fyi...I'm running the wires through a preamp boost so that they I can plug into amps and so that the amps will turn on as the sub amp requires 8 Volts preamp just to turn on.
Also, getting an aftermarket deck is a no go, if you've seen the dash of a TL, you'd know why.
Thanks!!!!
fresh2o
fresh2o
Fresno, CA
JIMMYSX95
