wiring nine.2x
could i wire 2 left + wires together and 2 left - wires together and input into left terminal on amp and do same for right side? maybe i screwed the pooch by getting a nine.2x, i assumed i could wire it like this for a 2 ohm load. if i trade this off for nine.4, how could i wire that to get 2 ohm load?
you can wire one set just fine, but that's alot of power for two components...at 8 ohms, you would probably be getting the right amount of power, but it's a waste of an amp...get a woofer with 600 rms (Ov.2)or two with 300(Kv.2) rms and use the amp for that...then you can get a good 4 channel hiphonics amp for around $200...you'd have a good sounding set up...just curious, why are you doing two comp setups...
i guess wire like this but just imagine the speakers are each 2 ohm? being as the comp set is a total 4 ohm?
crakerhead
crakerhead
Richmond, VA
crakerhead
