Wiring my batterys and amp
stilltippin863
ok here is my deal......i have a D34/78 yellow top in front...2 D31T's in the back with bus bars...one on pos+ one on neg-.......running 2 wires a power and ground 0ga from front battery to back ....i connect the power one to the pos+ side bus bar.....the ground one connect it to the neg- side bus bar....am i correct???? and then on the other battery .....run 2 powers off it with fuses .... and runn 2 grounds off it ....going to my amp.....IA 40.1
please correct me if i am wrong on any of this.......
also i would like to know should i runn my power wire from my alternator back or from battery back???
It would be easier if you could sketch up a diagram in paint, rather than try to explain it.
And the alternator to batt bank is not necessary. I'm assuming you already have the Big 3 done.
It's always kinda hard to decipher people's wiring in text, but it sounds like you have the correct idea on how to wire everything.
Only thing I noticed is that you have the positive from bat fused going to the amp. This isn't always 100% necessary, as the runs of wire are normally small and the chance of shorting them out is slim, but the fuses aren't gonna hurt any, regardless.
like this????
correct me if i am wrong....
so instead of running to engine block just run a ground to frame from battery?
no no. instead of running from the engine block to battery negative and then to the frame, you can run it from the engine block straight to the frame. It's not a big deal, but ideally you want your grounds to be as short as possible.
ohhhh ok...well when my ring terminals come in i will do that....
stilltippin863
stilltippin863
Florida
stilltippin863
