Wiring my 2 Kicker Comp 12s and Profile CA800
  • 3
TwiztedRolla
I have my 2 12" Kicker Comp VRs (4 ohm,DVC, 50 - 400 watts RMS). I ordered my Profile CA800 amp today and I need help on how to wire them for the best/loudest sound. I'm planning on building the subs into my trunk (spare tire well). Someone told me to run the subs parallel and bridge the amp, but I'm not sure if that would be best. Any help is greatly appreciated.
Profile CA800
800 watts Max Power
200 watts RMS x 2 at 4 ohms
300 watts RMS x 2 at 2 ohms
600 watts RMS x 1 bridged output at 4 ohms
4-ohm stable in bridged mode
^ that's what it says on the site I ordered it from.
Originally posted by TwiztedRolla Profile CA800
800 watts Max Power
Well, you have two options:
1. You can wire each sub in parallel to it's own channel so the amp sees a 2-ohm stereo load
2. You can wire each sub in series and then bridge the amp so it sees a 4-ohm bridged load
Either way will work fine. If you need a pic to help explain it better just tell me.
ur amp is not 1 ohm stable, so your best option i would say is to bridge it, or you could wire each sub parallel and one sub to each channel, either way each sub will get 300 watts rms. so you choose it, bridging u will have less wire showing, just one pos and one neg to the amp
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
337
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
699
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
731
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
738
TwiztedRolla
TwiztedRolla
Sunrise, Fl
DaBaller504
Dan Medina
    Jun 17, 2024
Doxquzme
    Jun 15, 2024
