Wiring JL 10w6v2 D4 into 4 ohms
jeeb75
i just bought this JL 10W6v2 subwoofer because i got a good deal on a floor model at the good guys after i blew out my infinity 10 perfect vq which was a SVC @ 4ohms. I am running it on a hifonics 2 channel amplifier running at 600 watts rms @ 4 ohms. Now I know this JL w6v2 has 2 4 ohm voice coils. The installer at the good guys wired it to 4 ohms. I just wanted to know if this is safe and is it able to work at 4 ohms because he has just wired it into one voice coil. I took out the sub and wired it back to 8 ohms because i am unsure if it is safe. I just want others opinions if i should wire it back to 4 ohms as it sounded much better that way. Thanks in advance for your replys.
Thanks for your reply, I checked the JL site and saw they recommended the 2 or 8 ohm configs. That is why i wired it back to 8 ohms, but it was sounding so much better at the 4 ohms. I am guessing the installer wired only one voice coil because that is probably the only way to get the speaker at 4 ohms. My amp is a 2 channel so it cannot run bridged at 2 ohms. I was wondering if i should take a chance and wire it at 2 ohms anyways. The amp i have is the hifonics nx600 so any opinions would be greatly appreciated.
So that is 300 watts RMS @ 14.4 volts going to that sub. The sub is rated @400 watts RMS so your best bet would be an amp that is around 400-500 watts into a 2 ohm bridged or mono mode. I would look into a different amp, assuming you would like to push the sub to it's potential. You could sell your current amp and take that money and put it towards a new one.
Good luck
jeeb75
jeeb75
Pleasanton, CA
DFW40
michigan born
    May 14, 2026
michigan born
    May 14, 2026
