Wiring issue? Amps cutting out, need help!
kidwolf909
Never Enough Money
Well unfortunately, we've got problems. The amps keep cutting out on me randomly, but typically at higher volumes. However, when I wiggle the wire that feeds the inline fuse between the battery and the distibution block, the amps cut out and then wiggle some more and they come back. I also notice sparks jumping across the fuse in the inline holder when you wiggle the wire!!! One wiggle it actually arced completely across the fuse and the amps went dead again... Sometimes it'll work fine for 45 minutes and then cut out, others only minutes. Sometimes the fronts go out briefly and the sub stays, but the fronts come right back...
Now what I cannot understand is that if it were to be a surge of power, then the fuses would blow, but they haven't. And if it's not enough power, then why does it work sometimes and not others... Now all i can figure is just crank down my connections as much as I possibly can and see what happens. The only thing that the amps share is power and ground and both of them almost always go out together and react in the same way with a blinking blue light. I called Alpine Tech and they had no clue whatsoever and said maybe a speaker is bad, but this is BS as all speakers including sub fire when they're working.
If anyone has seen this before please help me out! I'm running on original battery and stock alt if it makes a difference... system total is 900wrms at FULL tilt, so it should have enough power... I don't get it.
Thanks in advance though :-\
what size power wire? Also I would clean the batery terminal and make sure you got clean contact to the battery and through the fuse holder
The power wire is 4AWG Kolossus Kable from Knu. The inline has a 120amp fuse and my 2 amps only draw 80 and 30 watts, respectively, for the PDX1.600 and PDX2.150.
And yea I'll try cleaning it, with pepsi or coke, right? It's never been touched before though so it should be clean enough... And the system was fine with just the PDX2.150 and my RSD comps up until today when I added the sub, then it starts kicking off randomly :-\
kidwolf909
Never Enough Money
kidwolf909
Maryland
Mmmmm..Subs
