wiring in 85 caprice
85Caprice4d
Anyone know the wiring configuration for the radio?
Im trying to hook up my pioneer h/u and I cant figure it out.
There is a black, gray, and a yellow wire that was in one harness. I assumed yellow from my harness would go to yellow, black to black(ground) and red to gray.
But then I realised, yellow on my harness, was attached to orange, and the orange was for constant power (not ignition power)
Im baffled
yellow = Ignition controlled hot lead
orange = Hot lead
black = ground
dark blue and light blue = RH rear speaker
brown and yellow = LH Rear Speaker
grey and tan = LH Front
Dark and light green = RH front
Pink = power antenna lead
what about white with black stripe and gray with black stripe?? they both say somthing negative on it or somthing
//edit:
so i would go (hu first -- car wiring second
black to black
yellow(orange) to yellow
grey to red???
because there r three wire harnesses that come stock in the dash.
one harness is the power harness(3 wires, black grey yellow)
one is the rear speakers(not sure all)
and one is the front speakers(not sure all)
edit//:
Brown, Gray, Light green, dark green is one set
light blue, dark blue, yellow, yellow(brown stripe) is the other..
the hanress that came with my pioneer is a mess....
but;
red cable = [labled-acc] ?
black = ground
orange = [labled-battery]?
also, on my wiring harness;
dark geen = left rear positive
purple =right rear pos
white = left front pos
gray = right front pos
green (black stripe) =left rear neg
purple (black stripe)=right rear neg
add the three power wires, and then the only mistery wires are a a white (with a black stripe) and a gray with a black stripe
the gray with black stripe is labled right front neg, so i assume the white w black is left front neg?
exactly what wires are we talking here...on the deck harness itself? or your vehicle wiring
inside the car, all there is is 11 wires
POWER:
Black
Yellow
Gray
FRONT:
right- gray
left-white
REAR:
right-purple, purple (black stripe)
left-green(black stripe), dark green'
and then;
FRONT:
left- white with black stripw
right- gray n black stripe??
Why didn't you just the $15 harness? Solder the wires on the harness to the pioneer harness, and plug it in.....I don't get why people hack on the factory wiring.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Its so much simpler that way.
because this is my first h/u install, i dont know soldering, and I dont have money for the harness (lol)
okay, so then it connects as follows: (harness wires--then stock wires)
Power:
orange to yellow
red to gray
black to black
Front speakers:
gray to ?
gray with black stripe to ?
white to ?
white with black stripe to ?
Rear Speakers:
purple to ?
purple (black stripe) to ?
green(black stripe) to ?
dark green' to ?
The colors that came in stock wires are
Brown, Gray, light green, dark green
Light blue, Dark blue, Yellow, Yellow with brown stripe
so what is the correct way to hook up the speakers?
85Caprice4d
85Caprice4d
Milwauke, WI
85Caprice4d
