Wiring hu
correct. Unless you can get your hands on the mechanics version of Ford's electrical diagrams.. this would be the way to go.
Or you could pick up a DMM and test each wire to see what it does.
lol....all u gonna need now is a test light, which u can get at a dollar store or something......
with your key in the on position, use the test light to see which (2) wires light up and seperate those two wires.....now with the key in the off position test those two wires see which one doesnt light up.....the one that doesnt light up, connect it to the red wire, and the one that lights up only with ignition in the on position connect it to the yellow wire......And of course connect the black to the black........leave the other wires hangin...I dont even think your van has power antenna anyways soooo dont worry about it....
try that! remember DONT Short nothing out.......
i alreaty did that but 3 light up and 1 of those stays up when key on off. So im confused
Is it really so hard to look this information up? Anyway it took me about 5 seconds to find the information you need.
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Green
Illumination Blue/Red
Dimmer n/a
Antenna n/a
Antenna Right Front
Front Speakers 6" x 8" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 6" x 8" Side Panels
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
i alreaty looked at that and some of its wrong b/c all my negative speaker wires are black with white stripe and the ground is the solid black
which three lights up! and which one stays lit with key on/off......You're almost there man......
The orange and yellow with black stripes light up with key on and the green with yellow lights up with the key on and off
Wire up..........
Green/yellow stripe to the yellow wire
Yellow/black stripe to the red wire
****Black to the Black wire......
****USE your test light and connect the clamp to the black wire and touch the green/yellow wire.....if it lights up its the ground.....
It should work right there! Dont use the other wires....
Wire up..........
it it lights up which one is the ground the gree/yellow or black
also the red wire is supposed to be accessory not power what does this mean. I thought it was for a cd changer b/c the hu is supposed 2 be able 2 have a cd changer hooked up 2 it
12+ volt accessories just basically means that it'll power all your accessories when you turn the ignition on! meaning your headunit will turn on if you turn your key to the on position....
Ive hooked everything up right but when i turn my car on the hu doesnt turn of the little power light on the power button comes on but the display desnt come on and it doesnt play
PESteele
I wang on an 8 in a van
PESteele
annapolis
PESteele
