Wiring... Help!
djdownfawl
NJ
djdownfawl (1:35:43 AM): Ok do you see the KS 300.4
djdownfawl (1:35:58 AM): The H701 is placed under the passenger seat
djdownfawl (1:36:06 AM): he ARC 300.4 is an amp, its an amp for the Front component speakers
djdownfawl (1:36:11 AM): The HU signal is fed to the H701 processor, enhances the signal and it is then fed to the ARC 300.4 amp.
djdownfawl (1:36:17 AM): The signal then travels through 12 guage speaker wires back to the Front Component speakers
djdownfawl (1:36:24 AM): The CC 2002 is a Mono AMP for the Subwoofers that will be placed in the back
djdownfawl (1:36:28 AM): in the trunk*
djdownfawl (1:36:35 AM): The + 12v RED wire will travel through the side of the passenger seat and the rear seat, all the way back to the trunk, where it will connect to the CC2002 MONO amp and the KS 300.4 Component speaker amp through a distribution block.
djdownfawl (1:36:46 AM): If you look at the 300.4 connections, you will notice - a 4 channel RCA cable connects to it coming from the H701
djdownfawl (1:36:54 AM): And a 2 channel RCA cable to the 300.4 also
djdownfawl (1:37:11 AM): the second connection on the H701 is for the rear speakers
djdownfawl (1:37:15 AM): The third connection is fed to the CC2002 amp in the trunk
djdownfawl (1:37:27 AM): The lower 1 connection on the H701 are the Optical TosLink to TosLink connecting tot he Head Unit
djdownfawl (1:37:34 AM): the second one is the power and ground connecting to the HU's harness
djdownfawl (1:37:45 AM): Gnd/Power
djdownfawl (1:37:53 AM): The H701 has to be most likely be placed under the passengers seat.. i dont know
djdownfawl (1:37:57 AM): i am confused..........
djdownfawl (1:38:02 AM): because the harness is only about half a feet long
djdownfawl (1:38:06 AM): on the H701
djdownfawl (1:38:12 AM): If it has to be placed under the pass seat then i need longer optical cable and extensions for the h701 harness
djdownfawl (1:38:18 AM): the other issue is ..
djdownfawl (1:38:22 AM): If i place the 300.4 amp in the trunk, then its easier for me to place the distribution block on the hot wire right in the trunk and connect it to both the amps
djdownfawl (1:38:27 AM): BUT
djdownfawl (1:38:35 AM): i have to run all the wires that you see on the top
djdownfawl (1:38:42 AM): if i place the 300.4 in the front somewhere, lets say the drivers/pass seat
djdownfawl (1:38:46 AM): then the distribution block has to be placed by the pass seat and i can save the hassle of running all these wires all the way to the back
djdownfawl (1:39:00 AM): but then it needs a ground!!!!! chassis GROUND
djdownfawl (1:39:18 AM): //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
djdownfawl
djdownfawl
NJ
djdownfawl
