wiring guide for a total noob?
you don't use that to hook up your headunit like i said in the other thread. you need a wire harness.
go to crutchfield and look for the harness you need. easiest way would just be adding a random HU and see what harness you need.
I meant I was wiring my subs with that kit.
Do I need a wire harness just because I'm working with a ford taurus? Because I have lots of friends who have gotten new HU's and they never had to mess around with a wire harness.
thx
harnesses are good to have but with a qwick install they are not always around so u settle for splicing.... to me its qwick and ez if u know wat ur doing but if u dont u can screw up biggtime..
1999 Ford Taurus Stereo Information
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination Light Blue/Red
Dimmer n/a
Antenna Left Rear
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 5" x 7" Rear Deck
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
each car varies. but installing the h/u is mainly the same concept each time
hooking up the constant12v , accessory12v, ground, antenna and remote wires out to the amps...
I'm surprised the HU's don't come with one, or do you need a specific harness for most cars?
the headunits are universal ... that's why you should buy the wire harness specifically for your car. it's not a mandatory thing, but it's recomended to have a clean and safe install. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
your friends are telling you that you don't need to buy wire harness ... maybe because they just did the splice method, which is what shops usually do to get the job done quickly and messy. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
when the harness is not around i splice it up and make it very neat solder the wire and shrink tubing to wrap the solder. the wire tie and some tape to neat tuck it. as for shops u must be thinking of best buy or circuit city jobs most custom shops are real neat with that.
ah, thanks guys. I will check out the local stores to see how much I can get a harness kit for. If not, I'll just do the splicing method.
js09
js09
Columbus
js09
