Wiring dual 2ohm spearks to two strapped amps?
Wilso1995
CarAudio.com Newbie
I have 2 hifonics bxx3000.1d and 2 exm auido Dual 2ohm subs. My problem is I have never hooked up this big of a system. I have the power wire and batterys hooked up and amps kick on its the RCAs and how to wire the subs to the amp's or amp that im having a hard time figuring out.
That is alot of power, I mean like ALOT. You need some serious juice going to these kiddos! If you have that covered, you connect positive to positive then negative to negative on one sub. Then you connect that sub to one amp. Do the same with the other. Each sub will be 1ohm to it's own amp. Now connect rcas from radio to one amp in the input side. Then connect short rcas to the output side of that same amp. Finally, connect the other end of those short rcas to the input side of the other amp. You are done. Tune to your hearts content and bass on. You can also strap those amps but will need to gain match them. A tad bit on the complicated side. What is better than one bass knob? Two bass knobs!
6200bs
Use with discretion.
Wilso1995
CarAudio.com Newbie
Wilso1995
st johns
1aespinoza
