wiring dual 1 ohm btl to 2 ohm load
Link the two (+)s together on the woofer. Link the two (-)s together on the woofer. Now, from one of the (+)s go to the amp, and now from one of the (-)s to the amp.
Your trying to burn up his amp aren't you?...that is parallel wiring to 0.5 ohms.
OP you need to wire in series. run amp (+) to the (+) on coil 1. Run amp (-) to (-) on coil #2. The run a jumper wire from coil 1 (-) to coil 2 (+)
1 + 1 = 2 ohm in series
Wire it just like it is in this picture. The loads are different but the wiring would be the same.
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
WRONG
This.
and again
FAIL!!!
if your sub is a d1 and you want a 2ohm load just wire it how it is in the pic and you will have your 2ohm load. dont listen to the guys telling you pos to pos and neg to neg he dosnt know wtf hes talking bout
Jam1e
Jam1e
Green Bay
tEh ShOcKeR
