Wiring... do I have everything I need?
finalburden
Instead of paying someone to do my install, I'm contemplating purchasing all wiring and deadening and doing the install myself. That way, I can choose my own wire and gain knowledge at the same time. I need to know if I'm overlooking everything as I'm somewhat new to installs and could use some help. Here's a list of gear to install:
Alpine 9886
Morel Tempo 6
Fi Q 12"
Audioque 1200D
eD NINe.4
Here's a list of everything I've made thus far:
Thanks in advance for your help. Any guidance or info would be greatly appreciated. Sorry for the n00b questions but I just want to learn.
Looks good. but why do u need so much 4g ground cable? It should be as short as possible. Might also wanna do the big 3 with 1/0 instead 4 so u dont have to upgrade later on
I tried to overestimate everything as I'd rather have leftover than not enough. I was curious about 1/0 vs. 4 for the "Big 3." I guess I might as well go 0/1 while I'm at it. Thanks for the advice.
Just a little note on the turn on wire. I think knuconceptz has cheap remote wire (25 feet for like $2) or if not, you can get some primary from a hardware store for cheap. No need to use expensive speaker for that.
Awesome! Thanks. I didn't see any on the website so thanks for the advice.
For the amp fuses find out what the max current the amps draw. Get fuse sizes based on that. I would get the three-way distro block instead of two-way. You may end up wanting a 3rd amps someday. Price diff is negligible.
finalburden
finalburden
Raleigh, NC
wu501
